WinBin users ???
WinBin users ???
I'm still awaiting the delivery of my ADL Cable and Pocket programmer. In the mean time I have a few Newbie questions.
1. The first tab in WinBin, Flags what do these stand for? i.e. b7 see below.
VATS & Tranny Flags
b7 ?
b6 ?
b5 ?
VATS ?I think enables/disables VATS
b3 ?
b2 ?
b1 ?
Man-T Obvious
A/C Pressure Pecification Byte
b7 ?
P/S ?Power Steering?
N/O ?
b4 ?
b3 ?
b2 ?
b1 ?
b0 ?
VATS & KNOCK Sensor Diag
b7 ?
b6 ?
b5 ?
KNOCK ?enable/disable knock sensor?
b3 ?
b2 ?
VATS ?I think enables/disables VATS again????
b0 ?
VSS & EGR Diag
VSS ?
b6 ?
b5 ?
b4 ?
EGR ?
b2 ?
b1 ?
b0 ?
Thanx in advance
VATS & Tranny Flags
b7 ?
b6 ?
b5 ?
b3 ?
b2 ?
b1 ?
Man-T Obvious
b7 ?
N/O ?
b4 ?
b3 ?
b2 ?
b1 ?
b0 ?
b7 ?
b6 ?
b5 ?
b3 ?
b2 ?
b0 ?
VSS & EGR Diag
VSS ?
b6 ?
b5 ?
b4 ?
EGR ?
b2 ?
b1 ?
b0 ?
Thanx in advance
1 Post
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Yeah, I have the same questions too!! I'm sure that if I knew the source code I would be able to figure it out... but I'm not an EE by any means.
Also the Man-T check box doesn't necesarilly have anything to do with the transmission. I can change that flag in either winbin or GMEPRO and one program doesn't agree with the other! Go figure.
I know this may be alot to answer, but even a little bit of light on the topic will be greatly appreciated.
By the way this is for a '165 computer with 6Ev009.ecu file.
I need to know the same thing. I'm looking to change the fan operating mode from normally on to normally off on my 87 305TPI so I can upgrade from the 32B code to the 6$ code.
Help please!
Help please!
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
Night rider327
09-25-2015 04:47 AM
