How to lean out Cold Start Open Loop on $8D ?
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
There's 1 table I see thats directly related to "Open Loop" and Coolant temp for "cold" starts, called "Open loop Change to A/F vs. Coolant Temp" in TunerCat.
If I want to lean out the mixture a little for cold startups, is this the table I should be tweaking and how?
Current values are:
85.7
51.0
20.9
10.7
6.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
It changes to '1' at 20 degrees C, which is 68 F. My guess is making these '1.0' a negative number would do this, can that be done or is this correct?
I'm guessing the colder it is the richer the mixture will be with this table.
Current values are:
85.7
51.0
20.9
10.7
6.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
