Having problems with cable for laptop....
My friend who is an electrical engineer just finished building me the cable. I can't get it to work. I believe it is the max232. I have a power connection to the cig lighter. What's this about the 10k ohm resistor? Is this not on the schematic? Also, which dip switch do I flip on? Thanks in advance.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
If you're running a 1227165 MAF setup then yes, you'll need a 10K resistor between terminals A & B at the ALDL. If it's a 730, then no you won't need it.
I've got the 730. I was screwin around with it today, and I got it to work once. The instant I hit the gas, however, all the values froze at what they were last at. I kept trying it again with the car running. It wouldn't go into the screen with the data, until I shut the car off. Any ideas guys? Thanks in advance.
Car: 87 T/A
Dip switches?!? None of the circuits I'm familiar with on public disclosure have DIP switches. Maybe sonething new? Hmmm... Have you traced the circuit you have 'as-built' and compared it to one of the existing public schematics?
Car: 87 T/A
I wasn't trying to be coy, honest... Just that I don't know of any ALDL-type interface which has dip switches. I'm really not hanging in the shadows with a basketful of contraband designs...
He put the dip switches on there because he was sure about which of the wires was suppose to be connected or something. I have no idea. But that's taken care of now. I got the link hooked up and the program starts and I can even get into the data screens (it passes the part where it looks for a link and it beeps). But I still can't read any data. The values are all frozen. Any ideas? Thanks in advance.
Car: 87 T/A
Now I KNOW someone else has brought that same problem up before. Seems I recall it was an operating system or power-saver issue. Are you in a DOS-mode or native window? If not give that a try.
9192camaro
16
02-03-2019 12:21 AM
db057
08-11-2015 10:11 PM
