bbk 58mm throttle body vaccum leak
Car: 1988 Chevy Camaro Iroc z28
Engine: 383 stroker, Tpis Mini Ram
Axle/Gears: 3.73 gear ratio
Im curious if anyone else has run into this problem with the bbk throttle body. The other day I was tinkering with my car and decided I would smoke test my intake manifold to make sure I didnt have any vacuum leaks. Low and behold I found a pretty decent leak coming from the throttle plate bushings on both sides. Now, if my car was running on a map sensor i wouldnt be too concerned about it considering the map can self adjust for this. However, I am currently still using a maf sensor and now I wondering how much affect this could have on that. The throttle body itself is about 15yrs old but only has about 25,000 miles on it. So my next question would be before i spend 200-300 on a replacement throttle body, is the replacement throttle body going to do the same thing.
Re: bbk 58mm throttle body vaccum leak
If your town has a bearing supplier you can try there for bushings. Of course towns have to be a certain size before they have a bearing place.
Joseph Andres
Aftermarket Product Review
12-11-2000 03:04 PM
