How do you remove the ECM?
Car: 92 Z28 Camaro
Engine: 355 TPI
Axle/Gears: 10 Bolt 2.73
It's a 1992 Camaro with the 350, I have the cover under the dash off, but I can't see how to get the ECM itself out of there. Dumb question I'm sure, but I'd rather ask a dumb question than break something.
Car: check
Engine: check
Transmission: check
Re: How do you remove the ECM?
It is on a slide mount. Push the bottom of the ECM toward the front of the car until the velcro lets go and the ECM case clears the bottom edge of the mount.
Now pull the ECM down.
RBob.
RBob.
Car: 92 Z28 Camaro
Engine: 355 TPI
angelr
12-26-2015 09:59 AM
