no 350's in 86 lookn 4 a chip
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
hey guys, i'm not sure what chip to use for my car. It was a 305 tpi which has been replaced buy a 355 and not sure what aftermarket chip to get.. it's not a crazy built motor so i'm not askn for a custom chip but possibly a hypertech or jet or even a gm chip to install, i'm assuming my 305 stage 2 isn't going to give me as much as even a stock 350 chip could do, any suggestions??? thanks ahead of time... any advice would help...
Car: 86 z28
Axle/Gears: 3/73's
Re: no 350's in 86 lookn 4 a chip
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
With a custom chip you will get the best drivability and power. You will want a chip for a 350 not a 305 as there are differences.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Hopefully you have installed 22#hr injectors already. What are the camshaft specifications ?
If your wanting to have your memcal reprogramed for a 350 send me a personal message and I can assist you with the change.
Eric-86sc
08-24-2015 09:01 PM
