ecm will not communicate with scan tool
Car: 88 Iroc convertible
Engine: 5.0
Transmission: auto
Axle/Gears: 10 bolt 2.77
i have an 88 iroc vert w/ 305 LB9 and it will not communicate with my snap-on scan tool (model mt2500) i have gm factory service manuals i have checked every ground on whole car done all tests in gm manuals and scanner manual replaced ecm and prom have 4.5 volts on E and M of ALDL Ground on A of ALDL field service mode works normal gives me code 12
car still WILL NOT talk to scanner .anyone else had this???????????? any help?????
Re: ecm will not communicate with scan tool
Page 31 states faulty ecm , I haven't used a mt2500 in years and don't recall using a 10k resister to start data flow it must be in the key.
http://buy1.snapon.com/products/diag...0AppendixB.pdf
Engine: 5.0
Transmission: auto
Engine: 5.0
Transmission: auto
Engine: 5.0
Transmission: auto
tried all those tests & eveything is what it says it should be and still no communication
Linson
10-01-2015 09:50 PM
