TBI megasquirt question
have a microsquirt piggybacked to my stock ecu on an 89 TBI 305, Engine runs fine with stock ecu but as soon as i unhook the injectors from the stock ECU and hook the wires to MS, it won't fire.
any ideas?
any ideas?
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: TBI megasquirt question
When you first turn on the key with Megasquirt, you should hear the fuel pump run the 3 sec priming pulse and have the first LED light during this time. Then when cranking the first LED will flash as each bank of injectors fires. This is your first indicator that everything is hooked up and running properly.
It depends on which version of Megasquirt you are using, but in general your first stop for information should be the Megamanual. They have extremely helpful wiring diagrams there to help you figure out if you have yours setup correctly.
All I can say is go through the megamanual then, and look on the megasquirt forums. There are plenty of extremely knowledgeable people there more than willing to help you. I only have experience with MS-1, so my help is limited. I myself got help on the megasquirt forums when I first got my car running.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Pin 31 goes to dizzy HIGH,
Pin 20 (sensor ground) goes to dizzy LO
Pin 12 goes to EST control
Pin 11 goes to EST BYPASS
That worked for me on a 8 pin HEI (small cap TBI/TPI dizzy).
-- Joe
-- Joe
