16147060 rpm signal
Car: 1991 454SS
Engine: 454
Transmission: 4L80E
Axle/Gears: 4.10-1
16147060 rpm signal
Hello,
In my 1991 454SS truck with 4L80E and 16147060 I have ditched the tbi injection and installed a Edelbrock Pro-Flo 2 injection system and it includes a differend distributor(large cap hei with hall efect sensor) so all the stock plugs are unused exept for the temp sensor and the tps sensor.
That way I thought I can keep contol the 4L80E instead of buying a expenive controller.
The tranny works ok and goes into overdrive but not lockup so in my search I found out that the 16147060 pcm needs some sort of rpm reading to make it lock the converter.
Does anyone know how I should do that ?
I can take a rpm reading from the distributor hence my rpm gauge is working corect.
Thanks in advance
Thanks in advance
Car: 1991 454SS
Engine: 454
Transmission: 4L80E
Axle/Gears: 4.10-1
Re: 16147060 rpm signal
Do you have more info on that adapter?
I stepped up to the mpfi becouse it can see a 2 bar map sensor and it has a 1000 cfm tb.
A world of difference with a big block and supercharger.
Car: 1991 454SS
Engine: 454
Transmission: 4L80E
Axle/Gears: 4.10-1
I decided to use a switch with a light build in to control lockup.
I use the F and A conection at the ALDL plug for now until I have found a way.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1983 G20 Chevy
Transmission: 4L60
There are 4 wires into the module from the PCM on a normal 7 pin EST style module for a GM product. To make the stock PCM register an RPM signal you must ground the low signal to the module and the high signal wire needs to go the tach output on the HEI distributor. I have done this several times and never had an issue.
Also keep in mind for the transmission to shif correctly the PCM needs to be hooked to the TPS, MAP, and CTS sensors.
Car: 1991 454SS
Engine: 454
Transmission: 4L80E
Axle/Gears: 4.10-1
Great news !
You say ground the low signal to the module, but grounding it any place near the distributor be ok ? or does it really have to be the module itself ?
I am going to try it today and use a scaning software to see if the pcm sees rpm.
Thanks man !
Thanks man !
Car: 1991 454SS
Engine: 454
Transmission: 4L80E
Axle/Gears: 4.10-1
I just can not make it work that way.
I got the TPS, MAP, and CTS sensors hooked up.
I am used to the manual lockup switch bud really like it to make it automatic.
MikkoV
09-09-2015 04:25 PM
