Dyno Tunning
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Dyno Tunning
I spoke with a guy today about tunning my car on the dyno when I am done, he will give me 5 hours for $400. The problem is he mostly does newer F-Bodies 98-2011, where can I get a good software for my car(91Z-28) Is there a way to put a LS set up (ecm, sensors) in the 91.I may sound a bit dense here but the ECM is no where near my strong point, looking for some tech help here guys.
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: Dyno Tunning
i believe you can do whats called 58x...im pretty sure thats what its called. but you pretty much need to convert to cam and crank position sensors, coil packs, and a few other things. then have to have an OBDII ecm and harness. its almost not worth doing all those conversions unless you have a super sick expensive gen1 small block. if not, id just go lsx. BUT that guy just needs to learn how to burn proms!! some still do it, even though its just a tad more time consuming.
Re: Dyno Tunning
thirdgen software and tuning equipment.
www.moates.net
www.tunerpro.net
If you wanted to go LSx ecm,
www.eficonnection.com
www.moates.net
www.tunerpro.net
Re: Dyno Tunning
I will say you can spend the 400 and still have drivablity issues that the dyno wont handle. Granted the dyno is a safe way to tune WOT, cruise fueling(hyway mode) and spark tables for optimum. But I dont think it will address the acceleration enrichment choke cold start OL driving. Certainly the dyno could do all that but will the operator spend the time on dyno to do it? I bet not. Best you handle all yourself.
Is you car modded to require extensive tuning?
Re: Dyno Tunning
I have gotten a few PM 's on this so let me list what I have in the motor
4 bolt main 350 .30 over (355) Probe forged dish top pistons (keep comp around 9.5)
Doug Herbert Cam - 500/500 intake-284 / exh-292 / lobe seperation 112 / 108 centerline / 1200-6000 powerband
Pro-comp Vortech aluminum heads 190/62/70 1.6 aluminum Roller rockers
Double roller chain
Howard lifters
Holley Stealth- Ram (Vortech) adj fuel pressure reg / Bosch 36 lb inj (stage III)
Walboro 255 pump
Paxton Novi 6 or 8 lbs boost
4th gen rear with 3:42
Double roller chain
Howard lifters
Walboro 255 pump
Car: check
Engine: check
Transmission: check
Re: Dyno Tunning
https://www.thirdgen.org/forums/tpi/...-cylinder.html
Note that it is a sticky on the TPI board.
Since you are also into boost an EBL P4 Flash ECM is another route to take. See my sig.
RBob.
Re: Dyno Tunning
Found a shop in Orlando that has all the software, I will stop there next week to see what he can offer, thanks for all the input. If anyone has ideas keep them comming
darwinprice
17
10-11-2015 11:51 PM
LT1Formula
10-08-2015 08:34 PM
