7747/7429/8062 to C950??
OK, do any of you guys have any experience with swapping a wiring harness from a 7747, 7429, 8062, etc, to a Holley Commander 950?? Is it just a repin to the new connectors in a new location?? Anything end up not being used or do new circuits need to be made??
I want to use the Commander 950 to run my current TBI which is run by a 8062, all because there is a roots style blower being stuffed under the hood.
Thanks!
Thanks!
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: 7747/7429/8062 to C950??
I made a 7730 to HC950 adapter once, but i never got the injectors wired right. They worked, but they were operating in double-fire when I really wanted single-fire. it was because the 7730 engine harness has two injector control wires, one for each bank, whereas the HC950 uses 4 separate injector control wires. I think if I would have only used two of the four it would have wored instead of splicing two and two together.
dellman83Z
02-13-2015 04:34 PM
