How can you tell if you have an ECM?
Old 06-09-2011 | 11:37 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
As you no doubt already noticed from the title of the thread, I am not a mechanic. I know the question sounds dumb, but here is why I am asking. I have an '84 Z28 with a 700R4. I don't think it is locking up. There are many posts about how to fix the problem, but they all reference an ECM and have different parts/solutions. I always thought an ECM was the "computer". I have a chip installed behind the passenger dash. I think it is an ECM. The car was and still is carbuerated, but there is a computer port below the steering wheel. Is the chip behind the passenger dash an ECM? How can I tell?
I went to the TCI site, but they reference retro fitting into a non-ECM 700R4. Again, I am not retrofitting, the tranny is stock. I have upgraded to a 350 instead of the stock 305, but have not changed anything regarding the carbuerator. I will post the how to fix my OD in the tranny section of the DB.
Old 06-09-2011 | 11:59 AM
steven72192's Avatar
Re: How can you tell if you have an ECM?
well you can tell by checking under the passengers side kick panel it is a little silver box with plugs in the back of it, and the little thing under the drivers side is a DLC or data link connector, this is where you can pull the codes from im not sure if a scan tool can be pluged in and you can pull the codes that way, ive heard on these early GM cars there was a key like thing that you used to reflash the computer you would just plug it into to ports and jump them and get your codes that way i have not done this on my car so i dont know, hope this helped.
InfernalVortex
04-20-2021 12:31 PM
Falcon50
08-22-2020 04:26 PM
thunder57
11-07-2015 03:28 PM
Jlanz55
09-29-2015 09:55 AM
efiguy
09-27-2015 02:30 PM
