How to upgrade from HEGO to UEGO (Accel VII)?
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I have an Accel Gen 7 in the car i recently bought. I just figured out it has a HEGO sensor tapped into the left header. How do I go about upgrading to a UEGO wideband sensor? Not sure what all I will need to purchase?
Thanks!
Thanks!
Car: 1985 Vette
Re: How to upgrade from HEGO to UEGO (Accel VII)?
I have the Accel Thruster but I think it sets up the same way. I used an Innovate Motorsports LC-1. You have to go into the LC-1 and set up the output to the voltage range the Gen 7 wants to see, then switch the Gen 7 option over to UEGO. Requires a 12 v supply to the LC-1 controller. Mine works great. LC-1 has two outputs so I also put an A/F readout on my dash. You can usually find good deals on ebay.
Car: 89 GTA
Axle/Gears: 4.10
Do you run just one wideband on either the left or right side header?
Car: 1985 Vette
I replaced the narrow band sensor on the driver's side with the wide band sensor that came with the LC-1.
Car: 89 GTA
Axle/Gears: 4.10
Do you power your sensor with the car's 12V system or need a cleaner power supply?
Car: 1985 Vette
I just used the switched 12 v output from the Accel harness / relay. Very low current to the LC1.
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
I have the thruster system and I bought the accel wide band kit. Its in their catalog.
efiguy
09-27-2015 01:30 PM
