Wicked old holley MPI projection
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I bought a complete setup on ebay. For the manifold, rails, throttle body, and regulator. But it came with a harness and a old projection ECU.
I started playing with the software for fun. It's an absolute turd!
For starters. The "ve table", "spark table" are not tables. They are these weird graphs that you have to move around with the cursor keys. The values are hidden until the mouse is actually AT the intersection point then at the top left it displays the value in that cell.
It doesn't have a dist bias, so it assumes the dizzy is installed at 0 I guess.
I cannot find any way to specify injector size, although there is a strange graph called "injector volume" with RPM points.
Very odd system!
-- Joe
Very odd system!
-- Joe
RedLeader289
05-28-2019 01:47 PM
