268 xfi with bolt on stealth ram
Car: 89 TTA
My question is,will it run right with a tpi computer and a stage 2 prom?
heres the set up
comp cam 268 XFI Roller
L98 Iron heads screw in studs slightly ported
Holley Stealth Ram
Tpis 58mm throlle body
24 lb Injectors
Harris stage 2 chip
flowtech headers and y pipeborla cat back (no cats
2200 stall
I bought this stealth ram kit of the boards here with out really knowing what I was getting into. I dropped it off at a speed shop had a engine built and stealth ram bolted on,they havnt installed it yet but are already questioning the drivability and tuning,thx for any input.
heres the set up
Holley Stealth Ram
24 lb Injectors
Harris stage 2 chip
2200 stall
Re: 268 xfi with bolt on stealth ram
Driveability should be pretty good.have it installed and have a new chip made with for the new setup.The car will start and drive with the current chip..but not to full potential.
Email the guys at pcmforless..i think its called if you dont want to mess around with tuning yourself.List everything you have done to the car for mods.They will make you a decent chip.But for now..stick it in and break in the cam and let it run for awhile.Should still be ok to drive around for awhile..just not too hard on it.
believe me i know how you feel lol.
im in the middle of building a 383 hsr with a 280xfi,plus i spent money on getting all the tuning equipment..built in a laptop just for the car so i can tune on the fly aswell.
i was going to start with just building a 355 with the 268xfi and hsr..but its not expensive to stroke the motor ontop of that for even more power/torque so i went with it.
Car: 89 TTA
Just got my 268xfi build done,runs ok,a little rich and the idle is to low around "650" needs a custom prom,I placed and order with pcm4less.
ugh I hate waiting for things when im excited..
cool.id love to hear or see a clip of it running.keep us posted on your results after you switch to the new chip.
Car: 89 TTA
Well,I car back today,It runs,its driveable starts right up but idles low and runs rich,not throwing any codes.the shop tuned it the best they could,had it on ther scanner and all that.I have a harris stage 2 chip in it currenty,I ordered a pcm4less custom prom,I realy hope that brings it all together,cause right now Im not extremely satisfied has I expected To be.
That doesnt sound too bad at all.How do you like the way it runs and drives?
Car: 89 TTA
Its cruzzable,I havnt gave it more then half throttle,Its shiftng early.
Only has about 80 miles on it.
Idles a bit lower in gear Almost sounds like its gona die then it picks back up quik.
Its ok, its not ther yet,runs a bit rich
the air temp outside is only 50 degrees.
warmer weather and a new prom,should bring it around.
http://www.youtube.com/watch?v=9PRv02VaJuI
Shifting early might be due to not adjusting the tv cable.As for idling too low just reset it a lil higher.What is your rpm at idle..compared to idle in gear?Id assume you should be at 850 in park with that cam for now.
Car: 89 TTA
750-650 in gear,If it drops below 650 it compinsates up to around 750,surging between the two sometimes.
Ill get more video soon,that was my buddys cell phone,i recently ordered a digi cam.
Car: 89 TTA
with the new prom installed and weather approaching 50 degrees I went for a ride,so smooth,lots of power,havnt took it above 3000 im breaking it in slow,but I sooo wana punch it lol,feels great, awesome build for street.
glad to hear your happy with the tune.how is the car idling now and is it as rich as it used to be?
id love to see a new vid to compare and a driving vid to see it move lol
Car: 89 TTA
Idle is fine,exhaust smells good,it all finally came together. Thumbs up to PCMFORLESS.COM
Ill get a fresh video soon has I get A digi cam,last vid was my buddys cell phone.
awesome.i plan on using them soon for a base line tune on my 383 and then fine tune more on my ostrich.
Any updates on how she is running?Would love to hear a concluding post once the motor is broken in some more.
Car: 89 TTA
Its running very smooth,just did my 500 mile oil change today.Capped my borla and it really toned down can still hear the cam but its very quite,Its shifting a bit early under wide open throttle,but really gets it when you run it through the gears!still kinda cold out,low 50s,Im curiouse to see how it runs when the weather warms up.Ill get a video soon.
1 step at a time lol...id love to do 6spd and charger with low boost on the 383 im building.would be a screamer
1 Post
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I ran mine on stock chip, (little bigger build), but it ran great (minus off idle WOT), ran a bit rich, but still pulled very strong....I have had pcmforless do a chip, and was very impressed with the results, I have since datalogged and dyno ran to get a tune up chip done to get a way better tune. Alvin at pcmforless will send ya a 'base' tune then likes to have more info to adjust too.
Car: 89 TTA
yea ,thats what I was thinkin..I need to send mine back in,its tuned for a 195 thermostat and im running a 160, a small but much needed detail I over looked.
Car: 89 TTA
IDK what happined...this engine was STRONG,tons of torque,would spin the tires with no problem all the way throught 2nd if you please.that was before I left Iowa,after the drive to A.Z. I notice it ate some oil,and the oil was very black upon arrival,now It seems like my torque is gone.it wont spin the tires like it use to,still pulls hard but not like before.and my oil pressure isnt what it use to be either its fine at start up.
it use to never drop below 45 at idle and 60psi at cold start,now it around 55psi cold start then gets down gets down as low as 27-30 at idle after its warmed up, 45-50 psi under throttle cruzzing.
no smoke from exhaust at all,and doesnt seem to be eating oil anymore,and the oil is very clean.
Im really confused.wher did my power go?...Im thinking the worst, I have some sort of ring problem,and if so the engine is still under warrenty...time for a compression test?
Car: 89 TTA
this article sounds a lot like my situation.
http://www.camaroz28.com/forums/arch.../t-522432.html
Ill mess with the timing tomorrow and see whats up,still dont make sence why it was so powerful in iowa but not in AZ,is the climate THAT much differnt to make a HUGE change like that?...maybe I need another prom burnt,idk im confused and pissed....
If your car was a map setup then I would say that yes the climate would have more affect on the performance.Aside from that maybe its time to due some maintainace on the car now that its broken in.Recheck valve lash,header bolts and re-time the motor.Wouldnt be the first time Ive seen distributor hold down bolt losen back up on a fresh motor and the timing starts to walk away from you.Keep us posted
what are you wanting to break in?? did you use plane cast iron rings??
(from 50 years ago)
you have moly rings right? seats just about on start up.. if not 5 min later.
and you have a roller cam right?? NO Break in needed stand on that thing!!.lol
unless you like the black junk stuck to you head parts...
eng are made of steel.. IF it's not right, then it will eat its sell right there, on the spot.
they dont need break in like they did 50 years ago. is you bottom end made
out of plastic?? stand on that thing or it will be forever SLOW!
crook to cop:
OFFICER the Cuffs are a bit tight..
officer to crook:
sorry about that.. the cuffs are new give it a few they will stRech out.
(from 50 years ago)
crook to cop:
officer to crook:
Car: 89 TTA
Its all roller,It was super powerful in iowa but now im in az and its weak,its ok but nothing like before,anyways Alvin from pcmforless said the altitude makes a huge differnce,send him my chip and he will reset it for az climate.
Im sure everything is fine,im just over thinking and reacting.
Car: check
Engine: check
Transmission: check
Iowa has the advantage of being cooler. In the 50's - 60's this time of year.
Buckeye being in the mid 80's to 90's.
Although Arizona has the advantage of lower humidity. Currently 24% vs. 77% for Iowa.
The real wild card is the fuel composition. What differences are there between Iowa fuel and Arizona fuel?
RBob.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
http://www.aztpi.com
Car: 89 TTA
Thats good idea.Yea I had bad gas in it from flagstaff when I 1st got here,runs pretty good right now,but I refuse to take it out in this heat.
Not a horrible idea, being that a hopped up GTA I am familiar with tend's to flirt with the red on the temp gauge with how hot it is right now.
Car: 89 TTA
It never goes above 200-220.This hot air Just zaps the power from it.The paint isnt all that great but its shiny and Im not about to let the sun ruin that,and my interior hasnt been molested by the heat either,I had a few of these cars years ago when i lived here,Iknow what the sun can do to them.
Actually ive never seen it above 200,stays around 160-180
Car: 89 TTA
Finally got it dialed in!! and she screeeams,3.27 rear gear so she is a top end beast,nice launch of the line,barely spins,just barely,then pulls hard!
Of course you can break stand it,but thers no need,the launch is perfect,have to manually shift the gears,or it shifts abit early..but damn going down the freeway around 70 and stomp it,she pulls to 140 HARD and QUIK,screeams!! thank you pcmforless for the reburn,next stop AZTPI
#43
Car: 89 TTA
There is both elevation and temperature working against the engine. Although looking at the elevation of Olin, IA, it is at 800'. Where Buckeye Az is about 900'. Not much difference. Not sure what area of IA you are originally referring to. But isn't most of Iowa flat?
RBob.
RBob.
Yea,you are correct sir.when i first arrived it ran like ****,(bad gas from flagstaff),After it was out of my system the car came around
#44
Stangski09
11-14-2015 01:27 PM
Saxondale
Exterior Parts for Sale
09-07-2015 11:40 AM
UltRoadWarrior9
09-02-2015 08:24 PM
