O2 sensor reading .4 mv unplugged
Car: 1990 IROC-Z Coupe
Engine: 383
If I unplug the oxygen sensor wire, shouldn't the reading from the scanner be 0mv?
EDIT: sorry, .4 volts.
Car: check
Engine: check
Transmission: check
Re: O2 sensor reading .4 mv unplugged
The .4 volts is correct. When the O2 sensor is unplugged, which is the same as a cold sensor, the O2 amplifier chip biases the output to 450 mV (or real close to that).
So seeing .4 volts with the O2 unplugged is normal.
RBob.
RBob.
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Engine: 383
I am scanning it through the ALDL cable to my laptop (TunerPro RT).
Thanks for the reply, I wanted to make sure there wasn't a problem before connected the NBsim from my wideband.
mdtoren
08-16-2015 05:45 PM
eightsixseven
08-14-2015 03:09 PM
