Procharger w/ DFI Question
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I have ran DFI 6.32 on my N/A Camaro for quite some time. I am currently having some issues trying to tune since the Procharger install. Here's where we are at:
1. Car started and idled wonderfully with 1 Bar MAP sensor w/ Procharger.
2. Upon installation of the 2 Bar MAP sensor the car barely starts and will hardly idle. Nothing else changed.
Note* Within the tune in the program, we changed from 1 bar to 2 bar.
I'm thinking that in boosted apps., the fuel and timing maps need to be drastically changed, but we're not really sure where to start. There aren't any universal fuel maps within the program for boosted apps. Can anyone attempt to enlighten me? Maybe a pic of a fuel map on a boosted car. Thanks in advance.
Re: Procharger w/ DFI Question
ECU is Accel DFI Gen 6 with Calmap 6.32 software.
We created a base fuel map by inputting certain variables such as engine HP, injector size, max RPM and a few others.
It worked great with a 1 bar MAP when the motor was N/A, but now we're having fits tuning it with the 2 bar MAP.
I think the base program may work well with N/A apps., but the operators manual mentions nothing of tuning boosted applications. That's why we're in the dark.....
Hopefully someone will step forward and clue me in.
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
Did you change the ECU setting from 1 bar to 2 bar?
Yes I did change to 2 BAR in the programming. Like I said, car started effortlessly and idled beautifully with the 1 BAR, as soon as I put the 2 BAR on, the car would barely start and idle. It seemed way rich on fuel.
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Have you verified sensor readings? Only played with DFI once, never a boosted app but simple startup and idle should not be overly affected, make sure the sensor is reporting sane readings key on engine off.
Car: 1991 Trans Am
What type of map sensor is it? Not exactly the same but there was a guy on ls1tech that did the same sort of conversion for his stock ecu, turbo trans am. Every time he plugged the map sensor, it would do the same as yours. Turns out the sensor itself was bad.
Another guy had a similar problem and his turned out to be the wiring was backwards. 2 pins were switched around between the sensor and the harness.
accel, backwards, bar, calmap, conversion, dfi, e85, gen, lsx, map, pins, procharger, prochargers, sensor, tuning
