I only have one fan but the axcn bin uses 2?
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
I am only using 1 fan on my car and the axcn bin with the $8d definition has fan 1 AND fan 2 settings.
I'm assuming anything that I want to modify, (such as enabling the fan at a lower temperature) would be modified under the fan 1 setting, or would it be the fan 2 setting?
also, if im only using one fan, do i need to change anything on the fan 2 settings to keep it from trying to turn something on that doesnt exist? I dont want to get a check engine light.
thanks
thanks
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
Re: I only have one fan but the axcn bin uses 2?
do i need to disable anything in the bin so i dont get any service engine lights?
