Reading this ecm
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Reading this ecm
Hi!
A friend has this ecm in his camaro ACD # 88999194.
Can it be read by datamaster or does someone now what cind of ecm that is.
We need to buid a new chip for this blowercar.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: Reading this ecm
Its not the from the "ECM" you scan, its from the *.bin in the chip so you need to find out what code the chip is. Is it a TPI or TBI car? MAF or MAP?
or take a look on the 4 letters on the sticker on the original EPROM.
Did some search on the ECM nbr and is a MAF ECM (1227165) so depending on what year the car/EPROM is you need to scan it with a $32 or $32B or $6E def file. TTS will work fine or Tunerpro...............
/N.
/N.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Tjena!
Its a tpi whith a 730 ecm custom prom.
Can the memcal be a problem?
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I'm abit confused....
The ACD # 88999194 ECM seems to be a ECM for a 86-89 TPI car = MAF system.
But you wrote that the ecm is a 1227730? Which ECM does he have?
1227730 or 88999194? MAF or MAP?
/N.
/N.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Sorry answer for another post,forget the last answer.
This car is 89 camaro 383 blower MAF and i can get the number of the chip tomorrow.
Engine: 383 HSR TPI
Axle/Gears: 4.10
Hi!
I could only find DM35X32 at TTS.
And if it is the DM 35X32 were do you put the resistor like it says:
NOTE: 86-89 LB9 and L98 vehicles require 10K resistor modification in the interface.
I asume right over the aldl pins.
Hotrodboba400
12-10-2019 07:07 PM
