VATS in an 86 Camaro
I will be putting a 305 tpi out of a 91 z28 into an 86 iroc. My question is how is the vats system going to work? The 91 ecm will utilize it, but the ignition isn't equipped for it. I have no way to find out what kind of resistance is needed as I don't know where the donor car is.
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Re: VATS in an 86 Camaro
Since your car did not come equipped with VATS, to do the resistor mod you would need to procure the VATS module and wiring. A simpler approach in your case would be to disable VATS in the PROM.
Car: '91 RS
Axle/Gears: 3:42
This isnt 100% failsafe, VATS could be a problem, the best way is to
solder in an resisiter in the wiring (instead of on the key) or disable it by taking away/remove/disable Starter enable relay, VATS fuel enable relay and the passkey system then you dont have to worry about VATS being a problem.
Info about how to disable VATS completly : www.vatssucks.com
