accel dfi gen 6
Car: 1986,1988,1989 IROC
Engine: ?,L98,383 L98
Transmission: ?,700r4,700r4
Axle/Gears: ?,3.27,3.45
accel dfi gen 6
looking to replace stock ecm in 1989 l98 iroc to support new hot 383 build,will accel dfi gen 6 be able to support such a build and is the gen 6 programmable?
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Re: accel dfi gen 6
Yes it will support it and yes it is programable via laptop. Gen 6 is a DOS base so you would need an old laptop with 386 or 486 processor. If it's just a mild 383 and not planning to get more serious power out of it later then stock ECM will but a custom program chip will be needed to get the optimum performance.
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: accel dfi gen 6
Hi-
Just saw this. The old Calmap is so archaic, it is like cave painting to see it on your computer.
That said, I find mine works MUCH better if I run it from the floppy drive. That is, set Windows to run DOS and then put a floppy in the A drive. Running Calmap from the hard drive was too quick, even on my 1992 laptop. I always got "time out error" messages, and had to redo whatever I was transferring. NOW I run from the A drive. It runs fine.
[Sold] Accel 30# injectors
hydrolic144
08-29-2015 04:14 PM
355tpipickup
Alternative Port EFI Intakes
08-26-2015 04:08 PM
