90-92 350 L98 TPI SD with a T5, prom question??
1 Post
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Since a T5 was not available from GM with a 350 L98 from 90-92, do you need a prom adaptor to make this combo run correctly?
Re: 90-92 350 L98 TPI SD with a T5, prom question??
on mine i used a chip for a vette it was as close as i could get back then (10years ago)without getting an aftermarket chip
you can run with the stock chip without any ILL affects,timing at 12°,crank the fuel pressure up to 44psi and see how she runs..
A 305 TPI 5-speed chip will work ok, but a custom-burned prom will be the best option.
A Corvette prom has the oil tempurature sending unit enabled, which is not on our cars, and will give you a SES light after a few minutes of driving.
1 Post
Car: 91 Formula
I have the 305 TPI 5-speed chip but, if I'm going to do all this work I want it to run the best it can.
At this time I don't want to get into burning my own chip.
Any recommendations on someone to burn a chip for me? TPIS is good but, way over priced in my opinion.
Do you have to use a adaptor or can they just burn the stock chip?
Check with Ed Wright at http://www.fastchip.com/
1 Post
Car: 91 Formula
Thx. Kevin91Z for the recommendation.
Pac J
05-17-2020 10:44 AM
