ECM SCAN QUESTION ?
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
ECM SCAN QUESTION ?
I rented a Actron C9145 to read the Dionogistics for my 88' IROC. And it will not read anything not even the codes. The only thing it will do is the field service mode were it will flash the engine light on and off. Any scans I do it says "connection error" I thought the scanner may have been a issue so I plugged it into my 1991 Cavalier and it will read the codes if any and show all the dionogistics. The Cavalier uses the same port ALDL connection. I have disconnected the battery, pulled the ecm fuse, put the car in Neutral, started it up, ignition on only, etc. Nothing happens other than the error message. Any Suggestions anyone?
Car: 1988 IROC-Z28
Re: ECM SCAN QUESTION ?
Also I can scan for codes doing the paper clip test a-b.
Car: 1983 Trans Am ALL STOCK which is go
Engine: 305low
Axle/Gears: stock
does your scanner have an adapter to the power outlet?? I noticed use an Actron (connected directly to the ob1 outlet) didn't work then i found out it needed a power supply to activate the flasher which is why a paper clip works one prong has power and u touch it to the other one the engine light flashes. luckily i had a power outlet and pluged it in and it work perfectly
Car: 1988 IROC-Z28
Yea I pluged it into the cigerette lighter. As I said the scanner works fine I even was able to scan my 91' Chevy Cav. Which requires the same hookup.
I tried the jumper but did not get a flashing light. I am having similar trouble starting an 88 Trans AM 305 TPI. I don't get any spark and was trying to check codes, but they don't show. The Ignition fuse is fine, where is the ECM fuse you mentioned???
Skip
Skip
Car: 1988 IROC-Z28
Its been awhile but I'm still having the same problem.
any ideas?
anyone?
anyone?
anyone?
Bueller?
anyone?
any ideas?
anyone?
anyone?
anyone?
Bueller?
anyone?
Car: 1988 IROC-Z28
Come on guys!
nobody has any ideas of what this could be?
Car: 1988 IROC-Z28
Alright since no one knows what my problem is or any ideas. How about reconmending someone or a site to visit.
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Sounds like you may have bad ECM, can't think of any other reason for no comunication. Be sure to check your ECM power and grounds.
Car: 87 Pontiac Formula
Engine: 5.7L Crate Engine
Transmission: 5spd NWC
Hi,
I just quite my job at Actron. Most of their scanners provide limited ODBDI info. I have a CP9190 at home. I'll try to see if it works on my 87 Firebird. You would be better off downloading a free copy of datamaster, build or buy the cable, and using a laptop to check the ECM.
Lou
Lou
Car: 1988 IROC-Z28
Acually I have Moates tuner pro and a laptop that I don't use much with all the bells and whistles, and even that won't read anything. As far as a bad ECM goes I would of thought that as long as I can drive the car, the ECM is fine plus the paperclip test works too!(no codes)...
1 Post
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
AmericanMouse; by any chance did you figure out why the actron woudn't connect? (just bought one and having the exact same issue) Nitro-Nicky
if it does flash code 12 that tells you that ecm,wiring to and from are good and ecm is capable of diagnstic mode,I would suspect scan tool you are using to be problem
1 Post
Thank you for replying. Without an idea on that it was getting difficult to know where to start! Nitro
i also have no luck with grounding a-b with a paper clip. check engine light stays lit.
its an 1984 z28, 5 speed
any suggestions or advice?
NufNuffZ28
08-14-2015 09:12 AM
