gen7 help
Old 06-24-2007 | 04:37 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
gen7 help
here is a little backgroung on my car first...i have a 383 in my 67 camaro with a gen7 setup with an lm1 wideband hooked through the dfi..the intake is a holley stealtram....now for the problem...i really haven't driven the car much latley(for about a month)...anyway today i took it for a ride and it started to backfire like it was lean...when i got it home i hooked up the laptop to it and sure enough its real lean all of a sudden...the lm1 and the gen7 software are in sync as far as the what the AF ratio is...is it possible the fuel pressure regulator is or is going bad??if so what can i do to test it???any other ideas are more than welcome....any help would be appreciated....
mike
Old 07-15-2007 | 10:44 AM
imghost's Avatar
Re: gen7 help
Use a fuel pressue gauge to determine what is going on.
Old 08-05-2007 | 02:17 AM
1320jon's Avatar
Car: 87 iroc
Engine: 402 twin turbo lsx
Transmission: th400
Axle/Gears: 9" 40 spline MW, with 3.25 gears
Re: gen7 help
What is real lean? After sitting....I d guess a vacuum leak? That would cause false map sensor reading. What is the map sensor doing? Is it lean all the time?
89mulletbird
03-18-2013 09:15 PM
Recaro trans am
05-05-2006 07:17 AM
Hammered
12-18-2005 09:27 PM
sos
07-31-2003 10:24 AM
