smells rich at idle....gen7
Old 04-05-2007 | 04:32 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
i have a 383 in my 67 camaro.i am running acell dfi gen7 to control fuel and timing.i a have the lm1 hooked setup with the dfi as my wideband o2...the AF ratio on the lm1 reads 15:1(thats where i have it set),but the thing still smells rich...what would cause this???i would think that at that ratio it shouldn't smell like it does...any suggestions???the plugs look good and the timing map is around 17 at idle...any help would be appreciated..
mike
Old 04-12-2007 | 11:46 AM
Z69's Avatar
Z69
Re: smells rich at idle....gen7
I'd need more info on the engine....
17 at idle- stock gm efi cals have more than that.
15-1 afr- depending on the cam, that could still be too rich based on how the wb see's things.
Old 04-12-2007 | 03:22 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
too lean often smells "rich," but lean burns your eyes and throat a little more. Have you done the "free air calibration"
Old 04-12-2007 | 03:32 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
here is a little info on my motor:
comp cams 224/230 .503 .510 112ls
10:1 compression
30lb injectors
holley stealth ram
Old 04-13-2007 | 08:54 AM
Z69's Avatar
Z69
That cam isn't very big for a 383.
What's the idle kpa and rpm?
You did start with a base map based on 30 lb injectors?
At normal operating temp.
One at a time.
I'd add 5 deg SA in idle area. Cylinder head design will have an effect on this too.
Pull 10% fuel from idle VE.
You might need 15.5 to 16 indicated afr to clean it up.
Also if you have old gas it will stink too.
Luigytico09
10-01-2015 09:46 AM
Dwayne614
09-30-2015 12:05 AM
Glowsock
09-12-2015 12:09 AM
89fast5oh
09-08-2015 10:55 AM
Jk_Under
09-08-2015 09:13 AM
