megasuirt tunning help
hey guys im having to rush my megasquirt install
originally i was supposed to have about 2 weeks to be able to get the tuning part down.but now im down to a couple of days.
was wondering if somone could help me get a base tune setup just so i could get the car driveable for now
its a 3.3L v6 19# injectors for now. i just need help with a base timming map and a base ve map
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: megasuirt tunning help
Dave, You could do what I did and pull the stock timing and VE tables from the stock bin file of a simalar engine. Use tunerpro. That would give you a good baseline.
since im being so rushed with this,im gonna swap to a piggy back install for now,fueling was my main issue anyway.atleast now i dont have to worry about an iac just yet.or tcc lockup.
anyone know what the right bin and def file for a 90-92 camaro
use this
http://www.cruzers.com/~ludis/c3xref.html
and this
http://www.diy-efi.org/gmecm/
and this
http://tunerpro.markmansur.com/registration.htm
good luck.
