MAF sensor relay = burn-off relay ????
Old 01-21-2007 | 02:47 PM
patgta's Avatar
I went to Napa today to buy a burn - off relay, however they said they don't carry one (they can't find one in their system). After searching relay after relay we found a Mass Air Flow Sensor realy, it has the same 5 pin setup as the burn - off relay in the schematics. I'm guessing the burn off relay is the same as the MAF sensor relay, I know its a stupid question but am I right? And the relay is located on the driver's side by the wiper motor?
Thanks in advance for your much needed help guys
Pat
Old 01-21-2007 | 05:25 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Pat
There are 2 MAF relays the MAF Power relay and the MAF Burnoff Relay. Good news they are the same part number: RY109T
Here is picture of where they are located:
https://www.thirdgen.org/forums/atta...aff-relays.jpg
Old 01-21-2007 | 09:56 PM
patgta's Avatar
thanks a lot bro, for the clear up. Thanks for the pic this is exactly what i was looking for.
thanks again
pat
Old 01-21-2007 | 10:17 PM
patgta's Avatar
I couldn't find the part number on summitracing, when i googled it I found them on amazon. Or should i just go back to Napa and buy two of them from there.
Thanks again
pat
Old 01-22-2007 | 12:35 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
it would probably be more convenient to buy them locally.
Old 08-04-2024 | 08:47 AM
Henker's Avatar
Car: 88er GTA
Re: MAF sensor relay = burn-off relay ????
That’s not correct. The MAF-Burnoff-Relay has just four connectors (four wires): One contact NO (normally open). MAF-Power relay and fuel-pump-relay need five contacts; the connector-plug is equipped with five wires. The best would be, to take all three of them (MAF Power, MAF Sensor, Fuel Pump) with the five-connector-relay, so you can all of them interchange for diagnosis. For the MAF-Power use only the 10067925, because it includes circuit-protection to ECM and MAF-Sensor
Old 08-04-2024 | 09:15 PM
SbFormula's Avatar
Car: '91 Firebird Formula
Engine: SP383 Deluxe FIRST® TPI Intake
Transmission: Tremec T56
Axle/Gears: Moser 9" Eaton Truetrac Motive 3.89
LT3D (08-31-2024)
myzticc66
10-30-2018 03:29 PM
Eightyninef
05-24-2018 12:25 PM
johnny89345
04-15-2009 12:02 AM
Ward
01-17-2009 07:24 PM
400Z28Racer
03-01-2003 07:33 PM
