16149396 vs 1227727
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
16149396 vs 1227727
While searching for some info I stumbled across this information. If this is true does that mean that I can run $8D on a 16149396 ecm?
Info found at Untitled Document
"...Cars with the 91-93 3.4L DOHC V6 use a 16149396 PCM, which is identical to the 1227727 ECM, but with additional SRAM installed into a space which is left empty on the 1227727..."
Car: 1993 Pontiac Grand prix
Engine: 2.8/3100
Transmission: 4T60-E
no the i/o are different
you can see for yourself here
GM P4 ECM Crossreference
look at the schematics for both, and i/o schematics
i wish you could do that, becuase i would run 8f on my 9396
Transmission: TH350
Thanks for the info. I'll have to spend more time on Ludis site.
Charles
Charles
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Scot
Engine: 2.8/3100
uhh i dont think it will work, have you actually tried running 8d on the 9396 ?
Why don't you think it will work? They are identicle ECMs except for the added 2k of SRAM.
Scot
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Scot
Engine: 2.8/3100
well if you can run 8d, then you could run 8f
id think you would need at least to repin
dave w
06-11-2009 01:57 PM
