Innovate LC-1 WB O2 Help
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
so I got my WB O2 hooked up and running but when I go into Log Works it says I'm running like 22:1+ at idle, if I throttle it it dips to like 14:1 but any steady throttle its at 22:1 or higher, even if I dump way to much fuel into the car through custom prom,
I did the install and setup exactly how they siad, did the free air calbration etc.
on my 5V output its putting out about 1.8V
I'm using a USB to Serial could this be part of my problem?
is my O2 possibly no good?
any help would be great
usb/serial is prob OK. check the fuel setting. should be "gas 14.7" unless you are ethanol blend 14.3(?). defaults to "custom" at times.
now as a side note i had similar experience. i ran old software and it showed 13.0/1. ran logworks2 and it shows 15.8/1. but seperate WOT runs a week apart and much cooler and longer pull at load. so i need to do another blast and log.
69 Ghost
32
03-10-2006 10:56 PM
