Dfi gen 7 control outputs help!!
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Im trying to wire in my coolant fan control and the a/c control to shut off the clutch and to turn on the fan when the a/c comes on. i found the wire for the fan relay but i dont know what kinda input/output it is( gound , power ect) as for the a/c i have no idea where to start. any help would be great. thanx again.everyone for any help
Transmission: t-56
Sweet thanx, it worked out perfect , to control the coolant fan just wired it to the stock ground signal and set up the program. the a/c was a little more involed then hoped, but never the less works. thank's again.
ambainb
04-25-2016 10:21 PM
eightsixseven
08-14-2015 04:09 PM
