VSS buffer proposition
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Ok I'm almost finished installing my megasquirt and it's on a 91 350 tpi formula. From my research It appears that my stock computer takes the VSS input and outputs the correct signal to the speedo. I'm doing away with the factory ecm and was thinking about using a Vss buffer module off of either an older model or a tbi equipped car. could this work?
TMZIrocZ350
10-07-2015 12:09 PM
