Failed Emmisions-need help understanding scantool data
Help!!
I'm in California and have a 1984 Camaro with 2.8l automatic no a/c. The car would not pass emmisions because the NOx was too high. I got the EGR to work by-passing the EGR solonoid. (the egr is a positive pressure egr.) Then the NOx passed great but the HC and CO were over limit. I got the egr and it's solenoid to work and all the other systems seem to be O.K. but again the NOx is good and the HC & CO have hit gross polluter levels.
I have an Actron CP9145 scan tool with all this wonderful data but don't have any standards to compare with. (There are no fault code.)
1) Where can I get the standard to compare this data wtih?
2) The car is non A/C but the scan tool Reads:
AC Clutch On
AC enabled yes
AC request On
Is this correct??
If anyone has any input I would appreciate it.
Thank you,
Need to get passed smog and would like to understand this scan tool.
AC Clutch On
AC enabled yes
AC request On
Is this correct??
Thank you,
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
