Error Beep - "Limp Mode"
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
My car is currently running in limp mode. I'll go through everything that I have done to itiiiiiii and maybe you guys can tell me why my computer thinks something is wrong...
1) Replaced the tempeture sender with a mechanical one for my new guages
2) Pulled my stock gauge cluster to prepare for my new gauges
3) Put an open element airfilter on. (Plugged vacume line, reconnected sensor)
Thats what I've done although I noticed that I had my gauge pod out and it didnt seem to effect anything. Then once I pulled the temp sender it started.
NOTE: I did start the car w/o the old sender plugged into the comp. I then went back in connected it and ziptied it up.
HELP!
----------1) Replaced the tempeture sender with a mechanical one for my new guages
HELP!
I love computers just not in cars!
Stop me from going carb!
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
what codes is it giving you?
To get the codes (just in case you don't know how):
https://www.thirdgen.org/faq (under "Miscellaneous" near the bottom)
Well I reset the computer and the car is out of limp mode and running great. My error beer beleive it or not is my seatbelt warning backup because my idiot lights are disconnected.
