innovative lm1 and gen7
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
i read somewhere that u can wire the lm1 into accel gen7..does anyone have info on this???like how and what to wire???i did a search but really didn't find ant info on wiring it up...any help would be appreciated....
mike
mike
Car: GTP
Engine: L67
It's possible. You have to have version 4.0 or higher of CalMap which allows you to put a generic linear 0-5 table into the ECM. Then you have to program your innovate (or whatever sensor you have) to give a linear output where 0 volts equals 10.0:1 and 5.0 volts = 20.0:1. Hook the 0-5 volt output of your sensor to pins A&B of your HEGO connector on the DFI harness. Hook the sensor voltage to pin B, the signal return to pin A and you should be all set.
However, if you haven't bought the wideband sensor yet, you would do well to hold off. DFI just announced a cheaper wideband O2 controller at the PRI show last week. It will be a little higher in price than the innovate piece, but will be able to function as a data logger for the Gen 7 ECM in addition to being up to a dual-channel WBO2 with VSS and RPM inputs.
The base single channel model should be available in January, with dual channel pieces following shortly after that.
Car: 67 camaro
Transmission: t56
hey thanks dfiguy,thats great info....i do already have the lm1, but i still might wait to buy accel's unit...do u know if accel has it on their website yet????or anywhere else i could find more info on it????
mike
mike
