700R4 Pulses Per Driveshaft rev?
Car: check
Engine: check
Transmission: check
Re: 700R4 Pulses Per Driveshaft rev?
Originally posted by Firebat
Anyone know how many Pulses Per Driveshaft revolution the 700R4 puts out if the correct tires and speedometer gear is on a thirdgen?
Another way to look at it is that the VSS puts out 4 pulses per revolution. And there will be a total of 4000 VSS pulses per mile traveled.
The ratio of driven to drive gear tooth counts would give the pulses per driveshaft revolution.
RBob.
Car: check
Engine: check
Transmission: check
the vss puts out 4 pulses per revolution of ?
RBob.
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
4000, 700r4, driveshaft, firebat, mile, pulsates, pulses, rev, revolution, revolutions, speedometer, vss
