Idle problems with an Accel Gen 7+ DFI system
Old 09-12-2005 | 09:45 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
Engine: Aluminum Brodix-block SB 427
Transmission: Turbo 400
Axle/Gears: Moser 33 Spline 4:10
I just basically finished tuning the main part of the dfi system, but the car idles like crap. It surges from low RPM to high RPM. It eventually surges so low that it dies. I tried messing with the idle screw and the idle adjustments using the dfi, but I just can't seem to get it right. The car has a mild cam (.488/.495, 212/218) and 1.6 rockers. If anyone has an idea, please let me know. Thanks
Old 09-13-2005 | 12:18 PM
maniacc's Avatar
If you want, you can send me your .ecm file and i will compare it to mine. I'm still learning the programming, but maybe we can figure out the problem.
maniac@megamania.com
Later
Larry
Old 09-13-2005 | 04:19 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I used to have the same problem with my commander 950. the way I fixed it was to set the idle rich (~.8V for narrow O2) (14.0:1 AFR for WB O2) I have an even milder cam (204 216 @.050) but the lowest smooth idle speed for me was 700rpm. to get the speed right you'll have to mess with the IAC motor and the idle screw. The only way I could get a stable idle was to set the minimum idle around 650rpm with the idle screw. I emailed Holley about it, but they weren't much help.
tazs2000
07-15-2017 09:44 AM
Spyder_TheGamer
12-25-2015 06:07 PM
db057
08-22-2015 09:17 PM
marcusaw
08-10-2015 09:13 AM
