ECM Repairs..?
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
ECM Repairs..?
I recently had cause to open the 165 ECM fitted to my 88 LB9 IROC and noted that the MOV surge suppressor had blown. I live in Australia where some parts are hard to find...I was able to buy and fit a recycled 165 ECM but would also like to repair the damaged unit.
Please will someone advise me where online I would be able to source spare components for these older ECM's. I know they can be returned to GM through dealers for replacement but doing that from Australia will be expensive.
Car: check
Engine: check
Transmission: check
Best bet may be to find another non-functional ECM and use the part from that one. I did check an ECM I have here and the MOV is marked as such:
TNR
4417
8551
The 8551 may be a data code (51st week and 1985, fits the ECM). The 44 may be the voltage rating. Just semi-educated guesses. And, a 44 volt rating shouldn't be too far off. This device is across the B+ line entering the ECM. So it needs to supress what is left of the starter kickback (typically 65 volts or so). Could go on the safe(r) side and try a 25 volt device.
RBob.
TNR
4417
8551
RBob.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
https://www.thirdgen.org/techbb2/sho...&highlight=MOV
Perhaps Vader would be kind enough to enlighten us as to the specifications he uses in replacements?
On an aftermarket OE-style replacement 1227165 I have here made by Delphi, MOV is labelled as:
GEP9
4417
Does seem to confirm 8551 as a date code. Can't find any info on 'em though.
GEP9
4417
Engine: 305 HO EFI
ECM components
I wish we had heaps of US junk yards here in Oz, mostly we have yards full of Holdens which did use a modified 165 (same as but 160 baud only)... or so I've read and I will try to find some of these.
The GM rebuilt ECM I'm now using "labelled 86 TPI V8" had a MOV marked "TNR/5037/8544". My original ECM exploded and was unreadable. I also noticed what appears to be the odd zener here and there on my original 88, but absent on the 86 version.
efiguy
09-27-2015 01:30 PM
