ECM compatibility
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: check
Engine: check
Transmission: check
Re: ECM compatibility
Originally posted by tlaw
Will a computer from a 90 5L TBI work with my 88 5L TBI?
RBob.
Car: check
Engine: check
Transmission: check
I need to replace my computer, I was told it is causing problems.
Do I need to find one of the same year and exact engine for it to work.. or what should I look for? Thanks.
If you can't find one where the trans matches, move the PROM from your current ECM to the new ECM. The PROM contains the calibration information.
RBob.
efiguy
09-27-2015 01:30 PM
