ECM swap
Car: check
Engine: check
Transmission: check
Re: ECM swap
Originally posted by Pdiminico
Will an ECM out of an 89 RS with a 5.0L TBI Automatic work in an 88 IROC with a 5.0L TBI Automatic ?
RBob.
Car: check
Engine: check
Transmission: check
I have ECM 1228063,
will either of these work for me?
1227302 or 1227169
I have ECM 1228063,
1227302 or 1227169
I am correct in saying that your car doesn't have VATS? Little resistor in the ignition key?
RBob.
{edit: in a pinch a 1227747 ECM from a truck will work. Just need to be sure it is from a V8 305 w/automatic. As the PROM that comes with it will also need to be used. The '8063 PROM will not work in the '747. There are a lot of '747 ECMs out there.).
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The 8746 and the 7747 are your two other options. The 8063 does have VATS but its disabled. I had purchased an 8746 (kind of a dud) and ran into the VATS problem, of course even after I disabled it the ecm would only work intermittently. If your going to use one youll have to get a prom with the VATS disabled. If you have equipment to burn another prom its no big deal but most people dont have that sort of stuff. You could have someone burn you a chip for a nominal ammount to cover costs. IIRC I think some of the aftermarket chips came with no VATS. Id have to look. Im sure there are some floating around for cheap.
EDIT: I checked a hyperjunk chip I ahd and they still have VATS enabled.
Car: 88 IROC
Engine: 5.O TBI
According to a Cross reference Chart, the 1228063 ECM was also used on the 4.3L V-6 88-90. Will I be able to take the ECM as a direct plug-in or I will need to swap out the PROM and other items?
Car: 88 Camaro SC
Engine: SFI'd 350
Yes, any '8063 ecm will work. Just pop your prom in and go.
Edit: you may also have to switch calpaks if the engine in the car wasnt a V8. With the firebird that wont be a problem.
