Switch computer to non vats
Car: 89 Firebird (Project)
Engine: 2.8
I have had trouble getting my car started (project car) The security light won't go out. I have tried to jumper the VATS with all 15 different resistor values with no luck. If I get another computer that came out of a car with the same engine and auto transmission, and NO Vats, will it work with no problem or will I have to rewire a bunch of stuff. The computer has the same number on it but is out of a car with no vats.
The computer number is 1227302
Thanks for the help.
Michael
Michael
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
i have a 90 gta and put the accel gen 7 in there all i had to do was put a jumper in where there was a relay in left kick panel. nice and easy
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's not the computer that has the code, it is the chip inside the computer. When you were trying those codes, did you wait a minimum of 5 minutes between each attempt? Also, were you connecting those resistors to the connector with the purple/yellow & black/white wires?
