Fuel injected airgap
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Hi, im gonna buy that mainfold (prof product) next week..
I see they have nitrous bosses.. can I have those drilled
for fuel injection?
Im assuming I can drill the bosses.. put fittings.. get good injectors..fuel rails.. then put an LS1 throttle body on top..
or something similar.
The program running it all.. thats uncharted territory for me..
Does my project sound realistic?
Would this setup have any real advantages over a good carb ?
Thx for ur responces
for fuel injection?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
I've been contemplating something similar. Here are some interesting links:
https://www.thirdgen.org/techbb2/sho...hreadid=210448
https://www.thirdgen.org/techbb2/sho...hreadid=210366
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
1 Post
Car: An Ol Buick
Engine: Vsick
Re: Fuel injected airgap
for fuel injection?
then put an LS1 throttle body on top..or something similar.
for fuel injection?
WOT there isn't much difference between the two, but at any other throttle opening EFI wins. EFI is much more civilized when done correctly.
Engine: 3.0L/183
I see .. sounds complicated.. but ehh.. ill look into it.
thx for the info
thx for the info
are you talking about the single plane style intake or the dual plane style similar to the performer rpm intake? if its the dual plane style you may run into a problem with the height differance from runner to runner not being the same were as on the single plane they would be the same. just an observation
You do not need to make a plenum, many guys have been running a 4brl style throttle body with great results.
I picked up a 1000 cfm squarebore off e-bay new, just been waiting for edlebrock to release the victor EFI Intake.
If I find the pick ill post it.
Car: 1987 Z28
Originally posted by Zac's92
Victor EFI, like mine?
http://68.6.75.201:8081/~photos/albuo07?page=2
Zac
Zac
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
1 Post
Edelbrock part #
29785 for the maifold
3630 for the rails
Notice the "sample" cast into the bottom of the manifold. I got mine quite awhile ago through my distributor. Summit and Jegs should have them now.
Zac
3630 for the rails
Zac
Zac
Zac
Yeah I think that is pretty close to what I was refering to.
Thanks for PN.
Engine: 3.0L/183
very nice indeed
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
Car: 1987 Z28
Edelbrock part #
3630 for the rails
Zac
Edelbrock part #
3630 for the rails
Zac
$306.39 for the manifold
$78.99 for the rails
***wipes drool off keyboard***
i think i found a throttle body like that similiar on ebay. how much did you give for it and does it have progressive linkage? also hey has anyone drilled out the nitrous bosses and put injectors and fuel rails in? I would really like to do this but i need some confidence before i put my new vortec air gap through this
thats cheaper than a stealthram.. and would probably work just as good. only thing is you can use the stock TB...
I am going to start making my own EFI from my current Victor Jr intake. I bought some aluminum stock to mill some injector bungs from (its nice having access to a metal lathe) and weld them on myself.
One question about that aftermarket throttle body- Does it have provisions for a GM TPS and IAC ????
![](http://bigtimeauto.com/albums/Typhoon/aap.jpg)
How is the compatability of that LS-1 throttle body- meaning IAC's and TPS's to a 165' GM ECM ?? What is the flow comparison between a 48/52/58mm TPI style throttle body?? I was actually planning on reusing my existing TPI throttle body.
Heres what I have;
Running/driving engine in my Nova- 355, forged flat tops, scat crank, Dart sportsman ported CNC heads, Victor Jr, Holley 750.
This will be transplanted in part into my 85 Vette, combining my TPI components( 24lb injectors,rails,throttle body,sensors,HEI) running off my swapped in 165' GM ECM, chip by me, and a Comp roller cam which I cant remember off hand which one but its like 230@.050 and just over 500 lift- dual pattern on a 114 LC, which comp says is great for tpi or blown engines. Did I mention this will all be Procharged/twin intercooled @10 psi?! The procharger is already on the stock L-98 TPI in the vette.
The reason for using the engine from the Nova is that is has what I desire for the engine in the Vette, then I get to build my 400+ ci small block for the Nova!
This is why I am considering different throttle body options. I also have a serious hood clearance issue to deal with, so the fatory TPI style may be the way to go with an elbow/adapter.
Heres what I have;
If i were you, I would by a stealth ram and make a new plenum to clear that hood. Then you could use all of your stock components. I use Accel DFIV7's on my stuff so i do not know compatability to the stock ecm although i would imagine they would work you just would have to change plugs.
I thought about the stealthram, and modifying it- but doing it this way I have all the stuff already- the HSR I have to buy a bunch of stuff. Plus the Victor Jr flows more anyway.
Yeah, I understand that the Jr has a very small plenum (comp to the TPI anyway), but it will probably be doubled by the time I add an elbow to mate up with my TPI throttle body.
Where is a good place to search about plenum volume? Got any links???
1 Post
Car: An Ol Buick
Engine: Vsick
One thing that seems to be constantly missed is extending the rear wall of the plenum back past the rear most wall of the last runner. If you look at this simple box upper I made for my car, you can see that I carried it to an extreme while sorting out what worked.
If you attend any big meet where GNs are prevalent you'll see that the plenums on the sheet metal stuff is usually a min of 1.5x engine displacement. And at the Garret Musuem in Pidgeon Forge they have a Chev Indy engine on display. While you can't get any direct measurements, you can get a ruler close enough to approx things.
http://home.woh.rr.com/brucesgn/manifolds/dcp4136.html
Here's a pic of the next manifold to go on.
Originally Posted by 11sORbust
87_t/a, you need to sell me that TB. It's been sitting soo long the butterflys are going to stick
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Just to let some people know, and the question has been asked -
I am selling this now..
https://www.thirdgen.org/forums/engi...=1#post3006263
9192camaro
16
02-03-2019 12:21 AM
Fast355
12-02-2016 06:33 PM
