Help identifying memcal/eprom
Car: 1998 Camaro Z28
I purchased a 730 ECM (supposedly) with the following markings on the MemCal/EPROM:
16045915
27C256
E 5012AC
On the foil sticker:
Delco
APUY
2464
Also, 3J8351
Inside the ECM, there is a white bar code label
142119106326350, if that helps.
Any help identifying what I have would be greatly appreciated.
Thanks in advance!
16045915
27C256
E 5012AC
Delco
APUY
2464
Also, 3J8351
Thanks in advance!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: check
Engine: check
Transmission: check
Re: Help identifying memcal/eprom
APUY
APUY
RBob.
RBob,
Thanks so much for the reply.
Can I use this ECM for a 355 TPI AOD if I change the Cal and EPROM?
