DRAC Box jumper#8???!!!
Old 07-29-2003 | 09:47 PM
614Streets's Avatar
Which jumper is #8??!! Im going to jump off a cliff tonight , I cant verify which jumper is the ground / #8 . Ive got everything ready to calibrate it from 3.42 to a 4.10 ratio but I only see the 7 jumpers and cant find a schematic for them!
Old 07-30-2003 | 11:23 PM
HaulnA$$'s Avatar
There is no jumper #8 on a DRAC. The Programming clip on some instrument clusters has a pin #8 which is the common or "ground" pin. Removing the common pin on a programming clip will ruin it as none of the other pins will have a current return path. I have a file that I downloaded from the diy-efi ftp site (which is down at this time or I would have put up a link) that I can e-mail you which explains all about the DRAC. Let me know.
Old 07-31-2003 | 08:49 PM
614Streets's Avatar
Cool , thank you very much .
Old 08-26-2004 | 03:01 PM
cobb's Avatar
Car: 90 camaro
can some heelp me go from 273 to 342 with a step by step for the drac unit?
Old 08-28-2004 | 05:33 PM
614Streets's Avatar
http://614streets.com/drac.html
Thats all you need to do Cobb
Old 09-03-2004 | 11:41 AM
cobb's Avatar
Car: 90 camaro
I looked by my ecm and i can not find the drac unit, i think i might have to take apart the dash, so were is it, in a 90 camaro?
Old 09-03-2004 | 04:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
No 3rd Gen Camaros or Firebirds use a DRAC.
IIRC mostly trucks came with them.
RBob.
Old 09-03-2004 | 10:55 PM
cobb's Avatar
Car: 90 camaro
Than what do i do is it the same thing
Old 09-04-2004 | 08:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
By the previous post you changed the rear gears and now need to get the speedometer in line. If so then there are two gears in the transmision tailhousing. One or both (usually just one) of those gears will need to be changed.
There is more info on the tranny board for this change.
RBob.
Old 09-29-2004 | 02:13 PM
cobb's Avatar
Car: 90 camaro
Ok i found the drac unit on my 90 camaro but is does not look anything like the info i found on it, in the info they talk about a ussb unit which is under the speedo cluster. Texes instruments makes these. Does any one know how to fix the speedo with these. For now i know that i need to change the resister value from the outout of 2.73 to 3.42 with a 275/40/17 tire.
Thanks Tony C.
Old 10-02-2004 | 10:44 PM
onebinky's Avatar
Thats because your car doesn't use a DRAC, what you found is most likely a VSS buffer box. I believe alot of the early-mid 90's chevy trucks use a DRAC module, both minitrucks and full size.
InfernalVortex
04-20-2021 12:31 PM
Ed1LE
09-30-2018 10:14 AM
$750 L98
11-07-2015 03:26 PM
oil pan 4
Fabrication
10-06-2015 12:56 PM
Zell1luk
09-29-2015 11:36 AM
