Looking for free scanning software!!!
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Hello,
I am looking for some free scanner software for use with my HP Laptop running Win2000. I have an AKM Cable. I downloaded Craig motes's software and it won't run with the newer OS I have. I then downloaded WinALDL and it works well but is too slow and not enough information for me. I hope to find a good diagnostic software for my setup. I use the 165 ECM.
Thanx, Tom
Thanx, Tom
How about windows NT? Will that work? Replacing windows 200 with 98 is not an option for this laptop. I can barrow a laptop with NT though.
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
You can probably use Moates scanner if you start the laptop from a bootable DOS floppy disk. You will not be able to log data to a Win NT/2000/XP hard disk but the scanner should work.
Check out these web sites- http://www.moates.net or http://www.answersthatwork.com I haven't done it yet but these sites should steer you in the right direction.
Car: 1984 Corvette
Engine: Turbo 350
Originally posted by FIRECHICKEN
how do you make a bootable dos floppy?
Open a DOS window and type:
format a: /s
and hit [enter]. This will create a bootable DOS floppy. Then you copy Coates software to the disk.
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
XP will create a bootable DOS floppy too. If you are really lazy e-mail me and I will send you an image of a bootable floppy.
1Aauto
Sponsored Vendors
10-19-2016 08:50 AM
1Aauto
Sponsored Vendors
10-13-2015 03:06 PM
TMZIrocZ350
10-07-2015 12:09 PM
FueledSoul
09-26-2015 12:00 PM
