AutoXray Scanner help (MAP)
Does anybody know how to change the "Map" display in
the AutoXray-scanner?
My device is currently showing the MAP in volts, but i would
like to see it displayed in KPA.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I have one, and I don't think that units of measure can be changed. You will have to use a formula to convert volts to kpa's. Go here for a chart:
http://www.diy-efi.org/gmecm/papers/prog_101.html
You might have to do a search for it.
