where to buy a ecm scanner
Depends on your needs.
I'am satisfied with my AutoXRay:
www.autoxray.com
But i think the best solution to diagnose your car is
making your own ALDL-cable and connect it to a Laptop.
www.autoxray.com
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Can u just use a normal pc?
Is there a way I can pinpoint my problem I have in my car.. with a pc..?
I have a 1986firebird 2.8L v6 and I am getting HORRIBLE gas mileage! 12MPG! I did a tuneup too, plugs, wires, cap rotor. replaced maf, alternator, and a new egr valve.
Could be the O2, or need new injectors. The scannig software would tell you that. I would guess that unless you intend to use it severals times it might be better to let someone else do it. $300+ for scanning software is hard to justify for one shot.
wuts wrong with winaldl? thats free? Alls it would cost me is to make the aldl cable...
yes, i know how to pull codes. i'm just looking for a good scanner. i know the gm tech 1, you have to have a "E" pin adapter for 86-88 305/350 tpi. is it like that with the aftermarket scanners? as i have a 86 305tpi. thanks for your replies. tom
BumpaD82
02-26-2016 02:57 PM
