Need Ls1 Help on ECM
Need Ls1 Help with Diff ECM
Need some help on LS1 On ECM. Things I have ck into
Do not want stock ECM,I can not tune it ,Yes I know ls1 edit ,I WILL NOT BUY THAT!
Tuner Cat is coming with it in yr. or so.
Accel looks to be best Buy except you need At least a 350 MHZ laptop. my is a 166. Has a lot of goodes, Do not Know about reliability Tho, Can't find any info on that.
Fast - ECM I know about ,Has a good track record.
I know I will have to use E-Dist with Both
What I would like to do is use LT1 8051 Ecm, I need Bank to Bank or Sequential,Reason I have 42 pds in a 406, Pw right at 1.5 Idle geting Close Like to have 48 in it.
This Ls1 is 434 Cu.in Toy that I have made.
I thank you for any, and all HELP
Dale
Dale
