Holley Commander 950 on TPI
I was looking around on the net and seen where Holley offers the Commander 950 with an adapter harness to plug into the stock GM harness and sensors. It is user programmable. I was wondering if anyone else has looked into using this setup and if it would be worth the money.
Any input is appreciated.
Forget it....I just browsed thru this forum and discovered that all of the topics have very little posts. I guess I will go find an answer elsewhere.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I have it. Yes, it does plug into GM sensors. Is it worth it ? Well to me it was. Others on this board may tell you different. I find it far more convenient than burning chips. You can adjust all settings while someone else drives. Downside, no TCC or dash function control. Total cost about $900 with optional cooling fan control & knock sensor. Less than the $1500 for Accel DFI. Go to www.chevytalk.com on their EFI board one of the moderators there works for Holley & is very knowledgable on the 950 system.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Rick,
The 950 removes the MAF and replaces with a map sensor right?
The thing that pissed me off about the 950, and the accel setup was you bought the ECM, then had to pay extra for the management software. Thats so lame.
-- Joe
-- Joe
All Commander 950 systems come with software and communications cable. There are no hidden costs.
It will convert it to a speed density system. You can remove the MAF. The kit comes with a MAP sensor and other sensors too.
Engine: LC9, LT1
Interesting. I thought you had to buy the software. Maybe that was the accel then..
-- Joe
-- Joe
It comes with software & cable (Accel does not & it is lame) harness, ECM, heated O2 sensor, coolant sensor, MAP sensor, air inlet temp sensor, power relay, fuel pump block off plate (don't know why). I reused my TPS & IAC, they are not included. All the sensors are GM type & easy to find replacements. I had to modify the harness because of the Super Ram & where I mounted the ECM.
Car: 87 iroc
Engine: 5.7 ZZ4, AFR, Stealth Ram, Comp cam
Transmission: 1993 T56 viper internals w Spec3+
Axle/Gears: moser 9" truetrac 3:89
Re: Holley Commander 950 on TPI
QUestion about the 950. Can you still retain the factory ecu to retain the dash function and all the other things the holley does'nt control?
Car: 85 camaro z28
Transmission: auto to manaul
oem ecu doest control the dash and gauges. 950 cant control the egr. you could wire it just to control fuel or igniton. i love my 950
Car: 87 iroc
I dont have the egr anymore anyhow. I got the stealthram. I cant get anyone to burn the prom correctly so thats why I want to go with the 950. Any other feedback would be great from the people that have used this. The goods and bads would be very helpful on this system. thanks.
Car: 87 IROCZ
Transmission: 700r4 Shift Kit
Axle/Gears: 3:27
You must have just only seen the ones with less replies. Because there's a lot of Good info, and
Experienced people on here that help out a lot. .Hell there's plenty of posts with 10s of Pages
Lol! Yeah and it looks like the guy didn't stick around long anyway. This is the perfect place for people who love their thirdgens and enjoy sharing info and asking questions of other thirdgen owners. People who want McWalmart quick and easy and then have poor attitude about it should go elsewhere.
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
950, adaptor, cable, commander, communication, ecm, engine, gauges, gm, harness, holley, management, map, programmable, tpi
