Replaced heater core - Leaking coolant on headers
The heater core on my 1985 z28 burst and my interior got flooded with coolant. I replaced it and there doesn't seem to be a leak coming from inside or from firewall coolant hoses.
However there's still a leak that seems to be hitting the y pipe/headers causing it to smoke up. Very small leak it appears and only happens when I turn the car off.
Any idea as to what this could be? What else usually blows when the heater core goes?
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Replaced heater core - Leaking coolant on headers
could be one of the metl heater lines has a pinhole...have you tried a pressure test?
Engine: 3.4 / 5.0
Could be handling the hoses damaged / jolted something loose ?
Axle/Gears: 10 Bolt 2.73 Open
Where is the condensate drain on these cars? ANY fluid build up will come out of that drain. Might be worth checking.
Engine: 3.4 / 5.0
is that the ac drain?
theres like a tiny hole on the bottom of the evaporator housing
