hypertech 4028 availability
My fan switch on my 92z has went out.
I've already installed a 180 thermostat, so after searching this site I see the Hypertech 4028 is what a lot of people have recommended. So I was going to go with this.
But I'm finding this part has been discontinued, and I can't find anyone who has it.
Is there an alternative I could use?
My main goal, get the fan working again. Then as a bonus, hopefully have it come on sooner and help the car run a little cooler.
Re: hypertech 4028 availability
SW555 will work just fine
210F on 205 off
210F on 205 off
here is some napa part numbers if your switch is bad and you want to select a different on temp.
still haven't found an adequate fan switch. You might have to call up your local Napa to see if they have them.
MPE FS111SB On 245-Off 229
MPE FS112SB 229-Off 213
ECH FS111 On 220-Off 204
ECH FS112 On 229-Off 213
http://www.summitracing.com/parts/hyp-4028
http://www.summitracing.com/parts/hyp-4026
Thanks!
One question, when I look this up on Autozone there is a disclaimer 'does not fit'
I'm guessing because it's a different heat range, and not because it's wired differently or requires some kind of mod to work?
Is that correct? It's plug/play
Jet still makes temp switches at different on and off too.
https://m.summitracing.com/parts/jet-60600
Do you happen to know if it plugs into the stock wire, or is there a different pigtail that needs to be purchased. Been searching the forum, and not quite sure if it requires one or not.
I believe it crosses to
1S4394, D1882D, 2-8386, 98656, TFS8, 35946, 8386, 1802-98656, TS-136, 31444, SW555, D1874D, 53-13853
I've spent hours trying to find a replacement for my fan switch. It was 190/180 or there about. It may have been a Hypertech (I'd have to check my notes). I crossed referenced the SMP catalog with every known manufacturer listed but could only come up with rating in the 200+ range.
I eventually installed a Dakota Digital electronic fan controller. Works with my temp gauge sender, is fully programmable for set points, single or dual fans and a few other features.
Works very well. I have it set to have the fan on at 185 and off at 175 to work with the 160 stat.
